Head and Engine Identification
alfettagtam
Post by alfettagtam »
Hi Guys
I'm having a 1500 engine fixed up. I have a number of engines sitting around so was just getting the best bits from each. Some questions are getting raised:
Are the heads on single carb engines the same as dual carb? I'd heard they were different but don't know what that might be?
I also have some heads that are quite different pics attached. These other heads don't seem to have any depressions - high compression heads?
Finally, I thought I'd check what the original engine was. Found it has engine code AR30588. That's not on the list! Anyone know what that means?
Kerry
high compression head?
Normal Head
Normal Head
Re: Head and Engine Identification
Ive got one of those aswell. Yes the SC heads are different to Veloce heads. If if I remember a 30588 code is a carbed 33 1.5 (102hp). I think it’s Basically a 1.5 bore and stroke but with 1.7 chambered heads valves are bigger too.
Btw. if your selling the flat heads I may be interested. Or may Swap for. 1.7 bottom end ?
Lou.
Single carb heads are different, I can’t remember how exactly. But if your heads have twin carb manifolds then they are twin carb as the manifolds don’t fit a single carb head.
The flat heads are the earlier sud heads, the chambered / domed heads came with later 33’s. The pistons are different for each head, with the flat heads the pistons are dished instead, for the chambered heads the pistons are not dished.
See pics ere of the dished pistons. You will need to use the heads that match the pistons on your block, and if std you won’t see and difference in performance between the 2 different combinations.
https://www.google.co.uk/search?q=alfas ... 4Dg0YWcrUM:
The main difference between the SC and Veloce (twin carb) heads is the port centres . If you sat a Veloce manifold on a SC head the ports are a clog out the chambered heads you’ve got appear to be the later veloce heads . as they have enough meat to allow machining of the little cut outs used with the injected 8v engines. That’s why you have the injected gaskets between the head and manifold.
sudboy1490
Post by sudboy1490 »
As far as I can tell you have a 1.5 twin carb head and a 1.7 "chambered head". Looking at the inlet ports it looks like only the old gaskets have the cut out for the injectors. The inlet ports dont seem to have these injector cut outs? If so they look like mechanical heads rather than hydraulic from this side. If these heads have the same cam boxes as the 1.5 heads then youv hit gold...
Just reading this and had a thought, so gone to look for the engine code for mine and can not spot it . Where on the engine is it ? Thought i had noted it, but of course that will only turn up once I have found it out again. Thanks.
Engine code is on the RH side of the block just around the dipstick area.
Just a tip - give it a quick rub with some emery paper,draw on it with some chalk then wipe with a finger. Hopefully you should then be able to read it.
Thanks folks. Will do and let you know what it is. :D
Got it. AR30550 I reckon. :D
Engine Number Identification-. 301.02 - Single carb Sud 1.2 63hp
301.04 - Sud 1.2 ti 68hp
301.02/S - Sud 1.2 60hp
301.84 - Sud 1.3 74hp
301.60 - Sud Super 1.35 70hp
301.64 - Sud 1.35 75hp
301.68 - Sud 1.35/Sprint 63hp
301.24 - Sud 1.5 ti/Sprint 83hp
301.28 - Sud 1.5 ti/Sprint 95hp
301.46 - Sud 1.5 ti/Sprint/33 105hp
310.00/305.00 - Arna 1.2 60hp
310.10/301.68 - Arna 1350 Gti 85hp
310.16/305.20 - Arna 1500 Gti 95hp
305.00 - 33 1.2 68hp
305.02 - 33 1.3 75hp
305.04 – 33 1.5 ti 84hp
305.20 – 33 1.5 ti 90hp
305.50 – 33/Sprint 1.7 114hp
305.58A - 33 1.7 ie Kat 105hp
307.43 – 33 1.2 78hp
307.32 – 33 1.3 86hp
307.34 – 33 1.5 105hp
307.50 – 33 1.5ie 96hp
307.51 – 33 1.5ie Kat 95hp
307.46 – 33 1.7 16v 137hp
307.36 – 33 1.7 ie 110hp
307.37 – 33 1.7 ie Kat 110hp
307.47 – 33 1.7 16v Kat 132hp
307.55 - 33 1.3/1.4 IE specific to Greece and runs the Bosch L-Jetronic 3.2
335.01 – 145/146 1.3i Kat 90hp
332.01 – 145/146 1.6i Kat 103hp
334.01 – 145/146 1.7i 16v Kat 129hp
liost coutesy of alfisti .co uk
regarding your Nov 28 post.......how far is a "clog out" in the metric system?
alfadave wrote:Lou
It’s more than a “whisker” but less than a “country mile”
LooLooSud33Spider wrote:
alfadave wrote:Lou
:lol:
alfettagtam
KevJTD: that's the list I have seen before but 305.88 isn't on it!
Lou: Carbed 33 sounds right, I'll check with my guy on whether the valves are bigger.
I think I'm going to end up with a franken-boxer that mixes bits from a range of engines - I have some fairly radical cams that they are trying to use but we're all really keen that nothing hits anything else when it's running!
K
alfettagtam wrote:KevJTD: that's the list I have seen before but 305.88 isn't on it!
K
It's not is it! Lol, should have read through the post properly..
Strange, wonder if there are codes for engines that went into the 145/6?
Alfa 145 / 146 1596cc 8v boxer engines are AR332.01, the1712cc 16v engines are AR334.01.
Sprint88qv
Post by Sprint88qv »
Just found a reference to the 305.88 engine number that ‘ alfettagtm’ was asking about.
Apparently it’s a twin carb (dellorto drla36) 1.5 Alfa 33. I found it listed in the carburettors section of the ‘complete car’ part of the 33 workshop supplement (October 1988 - page 29).
Not sure if that helps.....better late than never....maybe.
Sprint88qv
Sorry, my mistake, that engine is listed with with dellorto 40’s or Weber 40’s.
StescoG66
Post by StescoG66 »
Now a thread resurrection.
The block I have is a 30736 which is 1.7 8v ie - is this the same as the 1.7 carb version and are 16v pistons compatible.
