ALFASUD & Ti & SPRINT - BOSCH DISTRIBUTOR - 1972-1974 - CAP = 44190 / ROTOR ARM = 47010s / POINTS - 22700 / CONDENSOR 35010
ALFASUD & Ti & SPRINT - BOSCH DISTRIBUTOR - 1974-1981 - CAP = 44190 / ROTOR ARM = 48890s / POINTS - 22700 / CONDENSOR 35010
ALFASUD & Ti & SPRINT - ELECTRONIC IGNITION - BOSCH DISTRIBUTOR - 1981-1984 - CAP = 44190 / ROTOR ARM = 48880s
ALFASUD & Ti & SPRINT - DUCELLIER DISTRIBUTOR - 1972-1976 - CAP = 44280 / ROTOR ARM = 47300 / POINTS - 22910 / CONDENSOR 33670
ALFASUD & Ti & SPRINT - DUCELLIER DISTRIBUTOR - 1976-1971 - CAP = 44280 / ROTOR ARM = 47300 / POINTS - 22910 / CONDENSOR 33440
ALFASUD & Ti & SPRINT - MAGNETI MARELLI DISTRIBUTOR - 1980-1982 - CAP = 46460 / ROTOR ARM = 47960s / POINTS - 23600 / CONDENSOR 33820
ALFASUD & Ti & SPRINT - ELECTRONIC IGNITION - MAGNETI MARELLI DISTRIBUTOR - 1980-1982 - POWER UNIT = 15210 / CAP = 46440 / ROTOR ARM = 47950s
ALFA 33 - 8v's - ELECTRONIC IGNITION - BOSCH DISTRIBUTOR - 1983 - 1989 - CAP = 44190 / ROTOR ARM = 48780s or 48880s
ALFA 33 - 8v's - ELECTRONIC IGNITION - BOSCH DISTRIBUTOR - 1990 - 1994 - CAP = 44190 / ROTOR ARM = 48920s
ALFA 33 - 16v's - ELECTRONIC IGNITION - BOSCH DISTRIBUTOR - 1990 - 1994 - CAP = 44190 / ROTOR ARM = 48780s or 48880s
ALFA 33 - ELECTRONIC IGNITION - DUCELLIER DISTRIBUTOR - 1983 - 1989 - CAP = 46050 / ROTOR ARM = 48371s
ALFA 33 - ELECTRONIC IGNITION - MAGNETI MARELLI DISTRIBUTOR - 1983 - 1989 - CAP = 46440 / ROTOR ARM = 47950s
The 's' at the end of the rotor arm part numbers means suppressed (no noise on your radio
Older intermotor part numbers are the same but missing the last 0 digit so a 44190 cap if older could be numbered 4419 but would be exactly the same
The tallest caps are Magneti Marelli screw on caps - 46440 & 46460
A medium height cap is Bosch clip on 44190
The shallowest caps are Ducellier clip on 46050 & 44280
Who knows which distributor is best for performance or reliability..... some rotor arms have built in rev limiters, some not
Hopefully this will be of use to some of you......
