306* C&B cams
SteffenJ3316V
306* C&B cams
Post by SteffenJ3316V »
I've got some 306* C&B cams I would like to put in my 1,7 8V mech tappet engine. According to my mates memory you need to machine down the cam house by 1 mm to be able to adjust the valves correctly with the shims.
1: How do you guys do it ?
2: Do I need to raise the compression ?
Jan Sud DK
Re: 306* C&B cams
Post by Jan Sud DK »
SteffenJ3316V
Re: 306* C&B cams
Jan Sud DK wrote:Close to your place I think ;-)
http://www.aabenraacylinder.dk/Topstykk ... 625765.htm
It's no probleme getting it done :) It's more whether it's necessary or not :)
902a
Re: 306* C&B cams
Post by 902a »
You have to measure the basic diameter of your cams. A smaller diameter means, you´ll increase valve play.
If so, there are two ways. The easier way is to use shims (from Alfa 75, Ducati, ..) on your valve stem to reduce play.
Second way is to machine down the cam housing. You won´t change compression ration as you don´t touch combustion chamber.
Ali
SteffenJ3316V
Re: 306* C&B cams
Thanks Ali. My mate remembered it right then :) I will have the camhouse machined then I guess :)
