Coolant drain plugs
Sprint88qv
Coolant drain plugs
Post by Sprint88qv »
Hi all,
Got a full winter’s work laid out for the Sprint and rather than do my usual coolant dump on the workshop floor via hose removal - thought I’d try the more elegant solution of the drain plugs on the underneath of each head. Quick question - I’ve usually been scared off by the thought of the classic steel bolt into aluminium head with lots of water involved….. so worried of drain bolt head shearing off. Is this normally fine and I’m being over cautious or have people had this disaster? Just wondering on best way to approach them - gentle use of long bar or impact driver? Cheers Ed.
Re: Coolant drain plugs
Coolant drain plugs are in the block.
Just warm the engine up first before removing them.
New copper washers if needed.
Sprint88qv
Ah ok thanks Dave,
I thought they were in the heads - will take another look… perhaps it’s my eyes that need sorting.
Sprint88qv
Result! Why haven’t I been using these drain plugs for the last 17 years… Dooh!!
Haynes say they are in the heads. P.40
Sprint88qv
Yeah, saw that. Then saw for real when underneath. 😁
Regarding your eyesight.........you should have listened to your mother.
Sprint88qv
