Two Show Dates.
Two Show Dates.
For those of you living north of Dartford AROC have just confirmed Spring Alfa Day at Duxford Sun 16th April and Southern Alfa Day Sun 3rd Sept at Chatham Dockyards.
Re: Two Show Dates.
Not been to Duxford for a few years, I'll make sure to have the GTV done by then.
See you there Tony?
See you there Tony?
Re: Two Show Dates.
I’d could take the spider. Maybe we could meet up and go in convoy Kev. ??
Re: Two Show Dates.
Thanks for the heads up Tony, hopefully see you there.
Kev, you will have the GTV done no problem, unless you are talking about another one you haven't told us about yet
Re: Two Show Dates.
Not buying anything else until I've sorted what I already have...
Just the engine swap to do. Whilst at it the front subframe will be blasted and powder coated along with a few other bits and bobs, radiator support panel for example.
Any suspect suspension bits changed at the same time, new arms most likely, rack gaitors etc.
Then the rear suspension will be done the same, blast and powder coat any bits. I'll resist going too mad though...
Sills will get the covers taken off and anything attended to.... Pretty sure the welder won't be needed
Amazing how time passes quickly doing these jobs though...
Re: Two Show Dates.
Sounds like a convoy, remember the other time Kev when you and Paul met up just off the A14. Maybe I could meet you there again?
Re: Two Show Dates.
Does sound like a plan, Lou has already mentioned it.
I asked Paul about it and he's keen, either in his 33 again or maybe a GTV Spider as he's been on about getting one..
Re: Two Show Dates.
The more the merrier
Re: Two Show Dates.
Sounds good. Be nice to see you all again, it has been too long.
