What tappet clearance am I supposed to set on a 1.5 Green Clover Leaf engine (105 hp) with shimmed tappets?
My Haynes manual says 0.7 for these engines against 0.35mm-0.40mm inlet and 0.45mm-0.50mm exhaust for the earlier engines.
I have lapped in all the valves and need to reset them but I have also seen it suggested that the earlier values are correct.
Does anybody have the 'correct' answer?
Thanks for any help.
Chris.
Tappets on 1.5 TI GC engine
Gary Orchard
Re: Tappets on 1.5 TI GC engine
Don’t believe the Haynes manual !
The 35-40 intake and 45-50 is definitely correct
chriswilliams
I understand my mistake!
When checking the opening and closing angles of the cam shafts I think you use 0.7mm opening of the valve as a reference point. That has got nothing to do with tappet settings!
I just miss-understood what I was reading.
Thanks for the clarification.
Chris.
Chris.
