Gearbox
Re: Gearbox
I may well give mine up for an earlier close ratio if I can find one
Re: Gearbox
John at Justsuds told me he has an early 1.2 gearbox.......
But Condition unknown!
Re: Gearbox
Problem is i think I the only way to find out what box is like is to either fit it or rebuild it
The
Re: Gearbox
Having a bad back, makes me reluctant to drop the whole unit and swap gearboxes any more!
I found a local enthusiast/mechanic with a pit. He will do the job for me by tilting the unit back, and just changing the gearbox.
He reckons 2 hours will be enough.
Some time back, decent engines and gearboxes were available from MoT failures.
Those have dried up now. But I'll keep on looking!
Re: Gearbox
Can you do that safely?
I only fetched the engine out through the top once by doing what your suggesting and it was a nightmare.
Re: Gearbox
Tilt the whole unit back. and drop the box out from below (in his pit).
Did it before at home.......but hard work to lift the gearbox back in when lying on the floor.....even with 2 of us!
alfettagtam
Re: Gearbox
Drop the whole engine and gearbox. I now have a hoist that makes it trivial but before that worked out a simple method using an engine hoist. You do have to get under the car to get to the gearbox mount but other than that you just unbolt the front cross member and the front gearbox mount. Use the engine hoist to lower the engine to the floor, then use the engine hoist to lift the car so you can slide the motor and gearbox out. easy peasy!
Re: Gearbox
Have a look at "Alfasud Clutch Replacement" thread 06 April.
Different ways to do it.
Re: Gearbox
The whine from my gearbox is getting worse!
Somebody has got a good one stashed away for a rainy day!
Re: Gearbox
I'd be more tempted to just get that one rebuilt dave, any that you buy would only look at recouping the rebuild costs anyway and the chances of finding a good used one are slim to none..
At least you'd end up with a known quantity..
Re: Gearbox
Its my daily transport!
Just want a quick swap.
Re: Gearbox
........and Charlie Skinner told me he didn't have any more sud gearbox parts!
Re: Gearbox
Have found a gearbox........Ebay item 153938791821
The guy drove it in a Sprint and has verified its ok.
Knowledgeable guy.....ex AR and race mechanic.
Now deals in pit equipment.
Other Sprint stuff for sale there.......message him for full info....
Including a Sprint shell with Lambo doors if anyone fancies that!
Re: Gearbox
Google Unit 7 Creations Ltd for his website
Re: Gearbox
Got the gearbox here.
Turns out its from a type 907 late 33.
Not sure which model though.....
The only clue is the diff is stamped 9/35.
Re: Gearbox
Dave. That simply means it’s got 3.8 diff ratio I’ll have look through my data To see which models used a 3.8 I suspect a late 1.7 33 poss 16v
Re: Gearbox
with electronic speedo drive?
Re: Gearbox
Looks like it had electronic.......but RH output shaft changed to cable drive
Re: Gearbox
Got the replacement gearbox fitted, and all is ok, and quiet!
Interesting guy who sold it to me.
He runs a Business in March, Cambs, called Unit 7 Creations. Deals in pit equipment etc.
But also manages a racing team in The States.
In early August his driver was leading a race, then heavy rain fell, and he had a shunt with Juan Pablo Montoya's car.
Can't remember the name of the race series.
Re: Gearbox
Good result Dave.
Nice one.
Nice one.
Re: Gearbox
I've changed my gearbox from a late Sprint type.......to a late 33 type 907 one.
The gear linkage is different......and the gearchange does feel different.
1st and 2nd need the lever to be pushed quite firmly left........I have missed a gear a couple of times.
I suppose its biased to the Italian side......and is in better condition than my old one.
Maybe I should have replaced the bush where the linkage meets the selector shaft?
But not too difficult to do now, with the gearbox fitted.
Re: Gearbox
Does any one have a Sud and a 33?
Same gearbox but different linkage.
First and second seem to need more than a normal push to the left on the 907 type late 33 box I've just fitted.
I keep trying to set off in third!
And trying to change down from third........to fourth!
Re: Gearbox
What about bending the gear stick Dave, to bring it closer to you, - or have you got a left hand drive gear change mechanism ??
Re: Gearbox
I didn't know there was such a thing as a LHD gear change mechanism!!
Re: Gearbox
I don't think there is, - unless you've just discovered that there is !!
Re: Gearbox
