Whine
Whine
Back out on the Cat and Fiddle with the sud after the restrictions were eased.
Got an annoying whine from the front over 40 mph in 4th/5th.
Its outboard vented disc, Sprint type.
The gearbox seems good.....goes thro all the gears ok, and no synchro issues.
Could be gearbox bearings/diff bearings/wheel bearings?
How do I know which?
The only clue is the MoT guy said the NSF wheel bearing had slight play........I replaced it, and the whine seemed to be less.
Maybe I should check/retorque the OSF wheel bearing.
Don't want to change the gearbox, and discover the noise is from somewhere else!
dave.armstrong
Re: Whine
I'd check the gearbox oil level first
Re: Whine
Anything that rotates can cause a whine, from the tyres to the engine.
Many is the time I've had cars brought in with a "noisy wheel bearing" that was just an aged hardened tyre.
You can easily sperate it being an engine while to a driveline one by dipping the clutch while moving, if the engine drops to idle and the whine is the same you can rule out anything engine wise.
If it stays on then you've got tyres/wheel bearings/driveshaft cv joints/diff bearings and internal gearbox bearings to shuffle through deciding which it is..
Re: Whine
Do not ignore it being from the back wheels either....so many times....
