Column switches
Column switches
Looking for a set of metal type column switches for an S2 sud
The set I need have the screenwash push switch on the end of the RH stalk
Just realised yesterday, that the set I have are from an early sud with no push switch.........which probably explains why I couldn't get the washer pump to operate!
Fiatchris
Re: Column switches
Post by Fiatchris »
Hi Dave ive got one with washer button, what do you mean metal? The stalk ends are plastic on this, is it different?
Re: Column switches
Chris
thanks for your reply.
The early S1,S2 suds had metal stalks with plastic ends.
I think the one you show is from an S3 sud?
Dave
Fiatchris
Re: Column switches
Post by Fiatchris »
AH. Think I have a couple more in the garage, will have a look tonight and see if I have what you need, I really MUST sort this lot out at some point, "found" 2 brand new FIAT 127 front wings and a series 1 Land rover gear box I'd forgotten about in the shed the other day! :D
Chris
Re: Column switches
Got the column switches today from Justsuds
Fiatchris
Re: Column switches
Post by Fiatchris »
Just in time for winter!! :D
Chris
