Alfa Romeo Alfasud Sprint 1712 16v (1984) Race Car
Taplow Sprint
Post by Taplow Sprint »
Body:
Just been repainted except the roof
Fibreglass Bonnet
Fibreglass rear hatch
Polycarbonate side windows and rear window
FIA approved Corbeau seat (exp after 2019)
Front air dam
MSA compliant roll cage, door bars, harness bar.
Mountny 310mm leather steering wheel
Racing mirrors
Sabelt 6 point harness (will need replacing for 2018 season if raced)
Suspension (all by AHM):
Specially made front and rear race springs and dampers Fully poly bushed
Suspension travel restrictors front and back
Engine & Ancilliaries:
1712cc 16v boxer by Bridge Motors
Baffled Sump
All bearings standard size
Bosch Motronic Fuel Injection
Bosch electronic ignition
Facet LP pump (switchable)
Adjustable fuel pressure regulator
20 litre aluminium fuel tank
Aluminium swirl pot
Ashley exhaust
Switchable cooling fan
Powervamp PVR 25 lightweight racing battery
Rev counter
Rev limiter with gear change light Squadra chip
FIA compliant cut-off switch
Brakes:
Front outboard discs
Rear discs
Ferodo DS2500 pads New 4 races ago
Wheels:
Compomotive 14” 6J wheels (ET14)
Tyres brand new Toyo R888r 185/60/14
Transmission:
1.2ti close ratio gearbox
Spare Gearbox 1.5
Full service, new big end bearings and cam belt start of the year only 3 race weekends competed since then.
Rolling road from 2015 shows 144 bhp the car weighs about 800kg without driver or fuel and sits in the 905kg weight range for its engine size in the CTCRC Pre 83 class.
I also have a 1712cc 16v spare engine that has been fully rebuilt by John Sismey see attached pdf and images. To be sold separately £800 ono. duncan@leftley.me 07733114085
Re: Alfa Romeo Alfasud Sprint 1712 16v (1984) Race Car
Are you able to give an idea of what you are after for the car complete?
Is the spare engine in standard trim or modified?
Any pics of inside?
