Does anybody know the exact size of the gearbox selector oil seal on a Sud gearbox?
Without taking it out it looks like about OD 25mm, ID 15mm (dont know depth).
Gear selector oil seal size
dave.armstrong
dave.armstrong
Re: Gear selector oil seal size
The part number is 60612499
Corteco 12015773B
16mm x 24mm x 7mm
http://www.mister-auto.co.uk/en/basket/
£6.16
Corteco 12015773B
16mm x 24mm x 7mm
£6.16
dave.armstrong
Whilst I am at it - the differential 'O' rings are part number 60502674
73mm x 2mm
73mm x 2mm
Hi Dave - the seals that are the worst offenders seem to be the ones that seal around the halfshafts. You need special tools to extract the pressed-on bushes to get to them, and I understood that they were no longer produced, but may be wrong (wouldn't be the first time). Do you have a part number/source for these items? If you are getting oil on your brake discs this is almost certainly where it is coming from.
Good luck sorting the rebuild!
Hi Dave, - fairly sure I've got all gearbox oil seals in stock, all Corteco parts.
dave.armstrong
I wished I d asked on Saturday !
