Is it possible to remove the steel oil fill pipe from the alloy rear engine cover? It appears to be pressed in BUT it's also possible that one of the rear cover studs is screwed in far enough to hold the pipe in place.
AOG
Oil fill pipe removal from rear cover
Alfaoldgit
Re: Oil fill pipe removal from rear cover
A bit of heat on the aluminium rear cover is generally enough to free it, - it doesn't need to be massively hot !
Alfaoldgit
Thanks John. I'll give it a try, I want to get it replated.
AOG (Chris)
AOG (Chris)
