I am about to embark on the final (maybe) big project on the Nova, replacing the standard 1.5 Ti engine with an Alfatune unit which I got from my good friend Graham some years ago. Graham is advising a full strip-down and rebuild before it goes back in the car, as it has been stored for some time.
Now, being an Alfatune 1600, the engine already has a number of trick modifications (this example is a 1500 block with a 1700 crank and special pistons, theoretically ideal for road use), including a large-capacity baffled sump. However, because my gearchange linkage runs forwards along the right hand side of the sump pan, I cannot use this special sump
As I will be mainly using the engine for road use, I probably don't need such an elaborate sump anyway, but I would still like to make sure that the engine gets as much protection as possible from oil surge. When I was talking to Ted Pearson at Auto Italia he suggested using a Trofeo sump, which was a standard sump pan internally modified by Autodelta for the racing series. This modification appeals to me as it would allow me to retain the existing gear linkage while providing some modicum of protection for the Alfatune engine.
Does anyone know what the Autodelta modification consisted of, or has dimensions I could use to modify a standard sump? I have an old 1500 engine block and oil pump that I can use to make sure everything fits properly and a standard sump pan that I can modify.
The standard sump comes with a single baffle plate...
But the only pictures that I could find of a modified standard sump date back more than a decade and come from the other side of the world...
The above may, or may not be similar/identical to the Autodelta design. I can't find anything else online.
Does anyone have access to homologation papers or factory modification manuals that might help? If not I will probably copy the Aussie design, as it seems suitable for the job (I know the one in the picture is a 16v), but I do like the idea of an Autodelta sump though!
Any help greatly appreciated!
