First drive in my Sprint I had a clicking while accelerating and what I thought was a crap thrust bearing. I changed the hub and drive shaft as one, clicking noise gone so that's fixed.
I also dropped out the motor & gearbox put in a whole new clutch & thrust bearing. The noise is still there!! I thought because depressing the clutch pedal and noise stopping it had to be the thrust bearing. So there's another problem.
It's a whining noise like a worn out diff but it's a 60,000km car, it's noisy in neutral and stops depressing the clutch. It's louder while accelerating and stops decelerating or unloading the motor going down a hill.
Now I repaired a damaged car that also pushed the engine slightly to the drivers side of the car in the accident, my theory is the CV was damaged because of this and damaged something more.
I drained the gearbox oil and took the sump pan off, the oil is clean and no metal filings were found, everything looks good as new like it should after 60,000km's zero wear in the diff & gearbox the synchro's are perfect and while driving the gearbox works and functions perfect.
I inspected the box when did all the seals and changed the gear selector shaft pictured below with an arrow, I don't think the problems there. I thought the output bearings were good but now I'm wondering if that's the problem (damaged in the accident)
I've got another gearbox on standby from an 84 Sud that's the same so can change the whole box but it's a shame since the one in the car is so low km's and the synchos are good. Should I try changing the output bearings and maybe the diff. I can do that from under the car instead of dropping the motor again. Any thoughts on what the problem is or experience with this before ? Sorry for the long winded post
