Alfa 33 s2 16v Resurrection
Re: Alfa 33 s2 16v Resurrection
Ah, now the wiring loom comment makes sense! :D Shame about the damage, easily done, but at least it's an easily repaired one as you say not like the modern stuff that hates being chopped into.
Good days work though JB, steady on with that good progress :)
Oggie
Post by Oggie »
Hi Jon,
I went through this 2 yrs ago with both the sills which was all down to a soft drivers side jacking point, ended up making inner sills and purchase 2 original part outer sills from Alfa Service in Germany. I didn't really need to do the offside but quite enjoyed getting stuck in to a project that my wife disproved of :lol: anyway I burnt through several t-shits due to splatter and one is caked in seam sealer which is indestructible even after 30 odd washes.
I decided to remove all the undersealer and painted the underneath in zinc primer so its easy to spot any potential rust.
Anyway keep up the work mate.
Hi Iain
Scary how the rust secretly attacks our cars . Glad you've sorted yours tho . Starting to get some where with mine now at last. Be nice to tick the welding off :D
Evening
Well I seem to basically have a solid 33 :shock:
Finished the sill and rear inner arch sill .then seam sealed it all
Then I cut out the fuel filler area,to get to the inner arch. Did a small repair .then made up a u shape piece to go round the top .then seam sealed it . Plus your see the new piece to go back in place of the old filler hole. Plus I put masking tape on .so when I'm finished. I've got a centre line .to drill a new hole for the filler. I'm going for an aero style filler cap. But I haven't got that yet.
So tomorrow I'll get that piece welded in and that's the welding done for the time being. :D
Next will be stud conversion on this side and brake upgrade.
That's it for this episode :D
Top marks mate, very good progress.
Cheers kev :D
That takes me back JB.
When I had my S2 the filler neck was rotted out and I grafted a box and flap off a Sprint into the quarter. Hot air gun allowed me to slightly bend the filler pipe to connect it back up to the tank. ;)
Kegsti66 wrote:That takes me back JB.
Morning Keith
Yeah that's what was going to do with a bike tank. But now I've found an aero style filler on eBay . Alot easier.
Good work - nice to have the updates.
Alfasixnut wrote:Good work - nice to have the updates.
Thanks mate
I'm glad I'm back on it :D
Johnboy wrote:Yeah that's what was going to do with a bike tank. But now I've found an aero style filler on eBay . Alot easier.
You big wuss! ;)
Mind you, i'm kinda glad you didn't do it afterall, makes mine unique! lol! :lol:
:lol: does look good chap 8-)
Well I did a bit more to the car . But not as much as I'd like . But that's what happens when you go out on a school night :lol:
Well speaking of the filler area ,that's now done, only negative is there's a bit of Wapping at the bottom. But that will be covered by the integrale arches :D
Also did a small weld on the bumper mount too
Then seam sealed the rest of the inner arch.
I'll underseal it all tomorrow. When on to the brakes :D
Just I little update today
The passenger side is now undersealed .so another job ticked off. :D
Been reading up about rebuilding the 1.8 block I've got. But I'm not sure if I'm brave enough to do it . I don't want to cock it up :oops: . It had a con rod let go. But there doesn't seem to be any damage to the crack. Just a small dent to the bottom of the bore,but away from the piston stroke .
I've got a spare set of heads to bolt on. Just need a sump rings shells and engine gasket kit.
Don't know what to do?
Have it crack tested ? - or bore another block to suit ?
Hi John
Yeah that does make sense to test it .
Cheers John
Evening peeps
Bit more progress today
Removed the rear axle brakes and supporting arms. Plus the brake balance valve thing as I'll have one in the for that.
started clearing up the axle. Shouldn't take to long with the knotted wheel . Then paint it all . Quite temped to spray it a brighter colour than black
We shall see tomorrow :D
Looking good JB.
Nice when you can tick another box. Sill looks great.
Cheers kieth
Well the jacking points are holding now the axles off :lol:
The problem is now I'm going to have to sort the front end out ,as I'm doing the back. ;)
Just I little update. The axle and arms are now all sprayed . Etched then primed ,then glossed. The the springs are done in standard Alfa red 8-)
Waiting on the polyurethane resin.then I can put the axle back together :D
Back to my day job. I'll Be working on this awesome Jag xe rs supercharged bad boy . I'll be respraying the rear bumper as his wife hit it :lol:
He told me to charge her loads as she's paying :lol:
Evening
Well got the polyurethane stuff today . So had a go at adding to the stock bushes . With poly bushes. They seam to stick out both sides of the arms . So what I've done is fill the area higher like a poly washer each side. The stuff goes off bloody quick :lol: so did a bit at a time. It works really well. I'm glad it didn't take out the stock rubber as they would have been rock solid . But there is a bit of movement in them . But they are alot firmer than stock . that's for sure 8-)
I've used just over half of the bottles . So cost me about £10 :D
Hopefully fit the rear axle back on the car tomorrow 8-)
didn't know there was the stuff available to cats your own bushes mate, looks like it could be very useful stuff, easy to use?
Hi kev
Yes been reading up on it .plus there's videos on YouTube. Some use polyurethane sealant like tiger seal , pu18 but its quite rubbery and similar to stock rubber. Purple Powerflex is 80 shore strength .black Powerflex is 90. This stuff I've bought.is ment to be 70. But I'd say it's firmer than that.
Very easy to use .just measure 50-50 by weight . But use small amounts.it pot life is 3-4 mins
great stuff mate, sure there are plenty of uses for it. seems like a good product
Yeah it is cool stuff
Just a quick update . Went out to check the bushes. They are now rock hard . Looking into it .I bought the wrong type :oops: I've now bought the right type . It's a 85 shore strength .so in between. The purple and black Powerflex from what I've read. Should be here Wednesday. :roll:
Morning peeps
Only a small update. The right polyurethane rubber turned up last week. I haven't tried it yet . As I'm on holiday in Corfu :D
But here's pick of it .
Big plus they sell Alfa beer here :lol:
lee16v
Post by lee16v »
Bloody hell Johnboy. She's getting life again!
Long time no speak mate. Hope all is well with you. Not been on here for a long time but will be dropping by a bit more now to see progress on the 33.
Loving what you've done so far.
Hi Lee
Yes been along time chap . Slowly getting there with the 33. But it's stalled again . Still waiting on Alex to sort out rear brake mod to disks . Need to give him nudge . Then I'll get back to it ;)
I see your old 33 got restored which is good news 8-)
You temped to get another?
Ayeup Lee! :)
Nice to hear from you again,
Don't be a stranger eh mate! :D
