I'm looking for some better door seals for my sud. It's a 4 door.
Both fronts have damage at the bottom from feet / getting in and out. I did wonder if a 2 door deal could be used and cut down?
Door seals, 4 door
JetJackson
- Contact:
Re: Door seals, 4 door
You could cut one down but most are knackered now, often with rust embedded in the metal clasps within the seal, not ideal!
Best just fitting new mate
http://www.woolies-trim.co.uk/c-37-side-seals.aspx
JetJackson
- Contact:
I did consider that. The problem with new will be the profile in the top corner of the door and getting it to fit correctly?
I had the same issue on our 5M, I ended up using ones from a 51 plate Clio (a part ex I was scrapping) The car was a three door, I ended up taking the ones from another scrapper and cut off the excess so that all my doors had the same seal. I had to source decent front seat belts too as mine were knackered, I ended up using mk1 Zafira rear belts (from the two seats in the rear) as there were no height adjusters or pre tensioners and the belt reel mounted in am upright position.
Just an idea guys .there's plenty of people selling door rubbers on eBay . You mite get one that's close to original.
