After some advice again if possible please
Did a fairly wet event at a venue called Llanbedr in west Wales at the weekend.
Struggled to get the car turning in as much as I would like alll day. Grip seemed fairly good in that we knacckered a pair of new wets in 6 stages (about 36 miles). Very little wear at the rear.
On the back we were running Yoky AO48's starting off at 22psi and ending up at 32psi with still no significant oversteer.
I have usually overcome the turn in problem by messing around with tyres and pressures at the back.
My questions are:
I am still running rubber top mounts with a coilover GAZ conversion with about 220lb springs. Should i go to solid top mounts (rose joints and if so whose)?
or
convert the back from the std setup to similar to BLS's tangerine rocket and go coilover bolt on unit at the back?
I await enlightenement
