TIX
Re: TIX
yeah,
but they are bloody vicious when they snag on an edge, tests your reactions!
they do a great job, but will put a steel wire through your eyeball in no time too,
caution and care, but results are fantastic
Re: TIX
I once had a piece of wire go through my cheek. So I only now use a wire wheel if their is no alternative and make sure I keep it angled away from my face.
Re: TIX
oooh!
i remember that tale from somewhere else a while back Crank, and it still makes me wince now!
Re: TIX
I've had plenty of wire stands hit me in different areas they only start to fall to bits when they are nearly worn out but you carry on using them untill they are bald . The other thing I can't stand is all the half moon bits the air nibbler chucks out they end up in your socks or you kneal on them
Re: TIX
They end up imbedded in the soles of your shoes, then you walk in the house and scratch the laminate floor.Simonsud wrote:The other thing I can't stand is all the half moon bits the air nibbler chucks out they end up in your socks or you kneal on them
Re: TIX
Which then ends up with the missus having a go and you having to replace the whole floorrcollie wrote:They end up imbedded in the soles of your shoes, then you walk in the house and scratch the laminate floor.Simonsud wrote:The other thing I can't stand is all the half moon bits the air nibbler chucks out they end up in your socks or you kneal on them
Would rather have it caught in the old man - far less painfull
Re: TIX
Etch primer good - acid etch primer betterSimonsud wrote:Hadn't actually put any etch at this stage black bits are rust convertor and grey is a type of filler you spray on it sort of self levels and goes of rock hard
Painted my bits with rust "converter" then acid etch, My Father always said don't rub back to the rust converter as once the seal was broken the rust will still come thorough
Re: TIX
I've had a slight problem with the rust convertor as it still seems to be active as little raised spots like micro blister have appeared under the paint in the engine bay and also on the suspension parts I've painted not a big problem as most is hided but don't want this to happen on top coat when car is finished
Re: TIX
Morning
Are you sure it's not water in your airline ? Do you have dryers or water oil catchers inline on your air ? That's what it sounds like to me
Re: TIX
Floors all cleaned up and primed then applied upol raptor its like stone chip but is a 2k product for pickup truck floors it stays flexible but it also rock hard and very durable and over paintable I also used this on inner wings and inside wings before painting them red
Re: TIX
Everning
That raptor stuff sounds interesting ! Need to get up speed with all this new stuff on the market ,I'm some out of touch with it all
Re: TIX
Ive told you before JB,
leading your Jetski hull will have an adverse effect on its perfromance!
Re: TIX
I know!
it comes on a roll now, "flashing" its called, and spot on for leaking Sprint roofs and windscreen apertures, and depending on the overlap, it doubles as a sun visor too!
Re: TIX
Chris has used this technique for years,
here we see him taking the "Bunkers Tour" with his then girlfriend, "the one that got away" Angela Merkel
Re: TIX
All acid etched then inner wings raptor, it can't be over painted for 6 weeks no rush loads to do and it needs to go in The oven for engine bay to be painted so need to wait for body shop to be quiet so I can take over oven . While I waited I painted all the front suspenion and cleaned up engine
