Just one more example which is different.
S3, 1.2ti gearbox, early discs. It has a spacer ring and a thin spidery spacer instead of the wide spidery spacer.
[attachment=0]image.jpg[/attachment
Gearbox driveshaft flanges
Re: Gearbox driveshaft flanges
Pretty much everything has been said, but to add to the confirmation, I used :
Big spacer with early 4 lug / stud disc
Smaller spacer with later 6 hole solid disc
The gearbox made no difference to the above, it's the disc - solid or not solid.
And finally I used a small spacer when converting to outboard discs and using a 33 driveshaft.
said i'd have a look when i got a minute....finally remembered tonight whilst sorting one for juniorKevJTD wrote:all good info guys.
i have also seen inner CV joints with a spacer inside the end cap.....just to throw a spanner in the works![]()
i have a dozen or so used shafts in my unit, one day i'll get around to inspecting them to find out the differences.
rest of what's left will be going shrews way so if anyone needs one then he's your man
