Clutch slave cylinder thread size
Posted: Sun Nov 10, 2024 5:59 pm
by Sprint88qv
Evening all,
anyone know the thread size of the fitting that screws into the top of the clutch slave cylinder (the hose coming from the clutch master cylinder). It seems to be 12mm diameter with a pitch of 1mm. In imperial it’s 26 TPI but I’m assuming it’s metric, so 1mm pitch.
Thing is M12 fine thread is 1.25mm pitch, so it can’t be that.
Anyone know what it is.
Cheers.
Ed
Re: Clutch slave cylinder thread size
Posted: Sun Nov 10, 2024 6:47 pm
by Sprint88qv
Ok, I’ve actually found a blanking plug on eBay that is m12 x 1mm pitch, so I guess they exist after all. 😁
Posted: Mon Nov 11, 2024 7:41 am
by Gary Orchard
It will definitely be a metric thread size not imperial.
Are you replacing the pipe- if so Sudshop sell them
Posted: Mon Nov 11, 2024 8:04 am
by Sprint88qv
Cheers Gary. No, not changing the hose/pipe, just want to blank it off when disconnecting from the slave cylinder, as want to drop the engine and been fighting with that £@&$#’ing circlip on the back of it and thinking, just disconnect and bleed again on reconnection. Usual fun and games 😁
Posted: Wed Nov 13, 2024 9:55 pm
Normal procedure is to remove and replace the circlip to avoid bleeding.
Have a look at Kevs post July 20th 2018, titled Helpful tips
Posted: Wed Nov 13, 2024 10:06 pm
.......on page 54
Posted: Sun Nov 17, 2024 6:45 pm
by Sprint88qv
Thanks Dave, I’ll give that a go. 👍
Posted: Sat Nov 23, 2024 2:31 pm
by Sprint88qv
Thanks, got it out 😁
