33 adjustable steering arms
JetJackson
Post by JetJackson »
Afternoon all.
My sud is LHD, running 33 front suspension and outboard brakes etc.
I recently took it to be tracked and wasn't really happy with the result and difficulty of adjustment, removing the steering arms to adjust.
I did a bit of googling and found that some 33s (with power steering I think?) had steering arms with an adjuster in the arm so they can be adjusted on the car.
Can anybody think of a reason why these wouldn't fit? If they will, does anybody have any knocking about in their spares pile they would like to sell?
Re: 33 adjustable steering arms
different sized bushes where they bolt to the rack, make sure to get the correct size
otherwise they'll fit i think.
sure john will have some
adsblacksud
Post by adsblacksud »
I’ve fitted them to both my Sud and 33, they make toe adjustment so much easier.
From memory I think we fitted a sleeve in the bush so the they fit the rack studs properly.
Thanks,
Adam
adsblacksud
looloosud1984
Post by looloosud1984 »
The powered 33 racks do indeed have adjustable sections and it makes adjustment much easier. the inner end bush has a bigger internal diameter. When I used them on my 33 (sud rack) I just knocked up a couple of simple sleeves to suit the sud rack studs to take the 33 bushings.
JetJackson
All,
I now have a pair.
Yes, the bushes are 12mm holes vs. the 10mm studs / bush holes on the 'sud rack. I'm also making a couple of sleeves. Bend is slightly different, but looks like they will fit OK.
Pictures to follow.
