Alfasud electronic ignition
Posted: Mon Sep 23, 2019 10:37 pm
Hi guys!
So my Nova engine is a 1.5 Ti, with a 1980 date code on the block, which should have had electronic ignition. However, when I got the engine it was minus the electronic ignition module/coil assembly (which is of course mounted in the battery tray area), only the Bosch JFUD-4 electronic distributor was in place, without any harness.
So I just replaced the electronic distributor with my 1978 Ti points unit and here we are, 22,000 miles later.
Recently I have repaired a Bosch CDI ignition box from a 1982 911SC, and apart from the number of cylinders, the magnetic reluctance pickup is virtually identical to the Alfa one. In fact, in researching possible replacements it turns out that the Montreal used a dual Bosch CDI set-up to fire the V8 (twin coil distributor).
Anyway, to test the repaired CDI box I dug out my electronic distributor and used it to trigger the CDI box. Works a treat. Which got me thinking it was high time I reinstated the electronic ignition on my engine.
Now, I have seen pictures of the Magneti Marelli Plex ignition module (it is a finned alloy casting with the coil bolted to it), and the inductive discharge switch module bolts to the heatsink underneath the coil.
My question is, does anyone have an example of the equivalent Bosch unit? The switching module is bigger than the Marelli one, 6-pins instead of 4. The part number for the Alfasud/Alfetta/116 Giulietta etc. is 0-227-100-123 and it is still readily available new for around £30.
Does the Bosch module fit the same finned heatsink as the Marelli unit? Or should I just make up my own heatsink out of 5mm alloy plate?
These little switching modules are interesting bits of kit - with a 36-1 crank wheel and sensor you could have 4 independent ignition channels, each with a dedicated coil, one for each plug. I always fancied having direct ignition on the Alfa boxer
Can anyone help?
Can anyone help?
