Hi JB.
the diff ratio is the same, used in quite a few 'boxes really the 4.11 diff.
the 1.2 ti & 145 'box have similar enough 1st and 2nd gears but 3rd starts to change things before 4th takes it a stage further but it's really 5th gear in the 1.2 ti that is the lowest geared of all. ok on paper they look close enough, but what does that all equate to? fair enough question...
for the comparison we'll use a 195/50R15 tyre dimension, common enough size for a sud/33/sprint/145 that could easily be found on any
so 3rd gear.
on the 145 at 5,000rpm you'd be doing 62.15mph.
in the sud you'd be pulling 5419revs to achieve the same speed, or look at it another way,
at 5000rpm in the sud you'd be doing 57.34mph
not a huge difference but we're starting to see where the sud 1.2 ti 'box has what can be considered almost "close ratio" top 3 gears..
so, 4th gear
the 145 at 5000rpm would be doing 80.07mph
the sud would need 5429rpm to achieve that speed in 4th,
or at 5,000rpm it'd be doing just 73.75mph
5th gear though is where you can feel the difference with the 1.2 ti ratios...
the 145 at 5,000rpm would be doing 96.29mph
the sud would need 5451 rpm to reach that speed,
or at 5,000 rpm you'd be just reaching 88.32mph
so although the numbers of the gear ratios themselves are pretty similar they make quite a difference in real times.
however, lets look at things another way...and a real bugbear of mine....
I know loads of you guys like bigger and bigger wheels, I don't. I like a car to accelerate as best as it can to a given speed, having it geared to do 150mph is pretty pointless if you haven't got 300bhp to get you there, or a legal amount of space to achieve it
we can chase lower gear ratios etc when the easiest thing is to lower the tyres rolling circumference
so assuming the usual upgrade tyre size of 205/40R17
the sud 5,000rpm in each gear goes from,
3rd 57.34mph to 65.84mph
4th gear goes from 73.75mph to 76.29mph
5th jumps from 88.32mph to 91.37mph
just in changing the tyre size. let alone what the trend for 18 and above does, let alone the changes in gyroscopic values which affect handling more with larger diameters..
but I admit they are nicer to look at
so the easiest/cheapest way to get better acceleration is to fit smaller rolling circumference tyres
