Any update on you headliner in the sud?
it's not going too bad mate but as you know yourself, bodywork repairs take an ageKegsti66 wrote:Well done Kev, you are really making good progress here. At this pace you will be able to take this one to MITCAR![]()
I remember the days when we used to change from disc to wire brush in our grinders !KevJTD wrote:a day off work so went up to do some more work on the fulvia.
whilst still working on the passenger side i thought i'd attack the front door as it is by far the worst and is a bit more variety rather than just starting on the other side sill![]()
corrosion was evident on the outer skin but also the underside was pretty poor.
first job was to take some accurate measurements of where the bottom edge is using the chrome door strip as a reference point.
the underside was then cut away and a repair plate made up. a bit of a pain in that it was too long to go in my little folder so had to clamp it down on the bench between 2 firm guides and fold it the old way, a hammer & dolly!
edge joggled to fit in the door bottom stronger than a butt weld would allow.
tacked into place keeping a check on alignment in all directions, the bottom lip is used for folding the new door skin over so could afford to be a little high but not low, but also had to be in the right place so it didn't sit proud of the sill when the door is fitted, or in too far...
checking it for alignment on the car is the only way to be sure
