vecchioalfa
Post by vecchioalfa »
BS25 wrote:Brilliant work, really good stuff! The standard of workmanship on this thread and every other build/restore thread on here is really fantastic! It's going to be great to see all these projects come to fruition! :)
Thanks for your encouragement :) I'm working round the firewall area and avoiding it as long as possible given the state of it :lol: , the car didn't look too bad at the beginning!
i keep saying it, but it's deserved. cracking work mate as always 8-)
Here Here!
Great detailing again Adi, amazing patience and dedication as usual :P
always nice to see an update, and thats another good size piece of the puzzle sorted.
vecchioalfa
Here Here!
Agreed, that's a big bit done, only trouble is the other side is the same :lol: I live in hope the other side may not be as bad as this side but there is more chance of seeing a Renault Megane with 2 headlights working than finding less corrosion on the other side :)
Gary Orchard
Post by Gary Orchard »
Glad to see the panel has gone to good use - I must have had it for 20+ years !
Excellent work in fitting it as usual
Hope you can find a wing rail now to finish the job off - will be nice if you can save your S1 boxing in panel at the back of wing rail though as these must be rare to see now
vecchioalfa
Gary Orchard wrote:Glad to see the panel has gone to good use - I must have had it for 20+ years !
Thanks Gary, good to see this forum works well with us all helping each other out with parts ;)
vecchioalfa
KevJTD wrote:i keep saying it, but it's deserved. cracking work mate as always 8-)
Thanks Kev, we will soon have all these SI Ti's lined up at a show or 2 :)
Brilliant work chap amazing finish. Better than factory. But then again that's not difficult :lol:
sud_1.5ti
Post by sud_1.5ti »
Great work. Wish i had these skills.
vecchioalfa
sud_1.5ti wrote:Great work. Wish i had these skills.
vecchioalfa
Johnboy wrote:Brilliant work chap amazing finish. Better than factory. But then again that's not difficult :lol:
Yes your not wrong there mate.... :lol:
Wing mounting rail, - pm sent
vecchioalfa
justsuds wrote:Wing mounting rail, - pm sent
No PM John as far as I can see, I will try to send you one, thanks Adi
vecchioalfa
Ok chaps, time for an overdue update or 2......
After fitting the inner wing panel there were a few bits to finish off...
These captive nuts are stainless and came off ebay, if anyone wants to know I can upload the item number..
vecchioalfa
The next job was the wing mounting rail, John at just suds came up with one for me, it was a new panel that had been fitted to a project that never got finished, thanks John ;)
I took that rail along with the other rail I already had that was new but had rust in the seems through bad storage and 1/2 the scuttle panel down to the strippers....
After some metalwork both were given a coat of etch primer.....
vecchioalfa
Now to remove that rotten foam filled old rail.....
vecchioalfa
With a house move approaching I needed to get the shell mobile, those of you who have followed this rebuild from its beginning 4 1/2 years ago will remember I had already made up a frame for the rear of the car so I needed to do the same at the front and join them together.
The hardest part was getting the uprights vertical to the top plates that fit to the strut top points
I now have the front and rear sections bolted together so the shell is ready to move when needed
Greencloverleaf pat
Post by Greencloverleaf pat »
[/quote]
Could I have the eBay item number please as I need some for my sud and great work on your sud as usual I'm sure it's going to look amazing when it's finished :).
vecchioalfa
Hi,
No problem, here is the link to the item off ebay Germany:
http://www.ebay.co.uk/itm/10-Stuck-Kafi ... 53eece1f53
These are spot-on on size and stainless so no further problems getting the front bumper off :)
The seller also has a listing in English although this one in german is a bit cheaper,
Cheers,
Adi
Hi Thanks for that as well. I will need some so I can be confident my petrol tank is to remain attached to the car when it finally rolls out of the shed.
Impressed at your efforts. I once restored a rare 50's motorcycle to that level, but could not do it with a car. Too much battling with ugly bits I think.
So much on a motorbike is seen and so a different standard. I would like to say better engineered but I do not think that is true as much of a Sud is very well thought out.
Thanks junior
vecchioalfa
Wing mounting rail is now on, all welds neatly ground back and 1st passing of seam sealer added
Another big job done....
vecchioalfa
Next up..... O/S Door.....
Getting a good door gap is impossible unless the hinge pins are in tip top order as we know, mine were badly worn and as they are welded on it presents a bit of a problem. these are originally 8mm tension pins top & bottom. I decided to do something better. There is not too much thickness on the hinge bodies and removing metal in situ is not easy as you can imagine. I decided to open the holes out to 8,20mm and make up some solid hinge pins from the shanks of some 8,20mm long series drills
I ground the shank of the flutted section of the drill wit the dremmel with a cutting disc on it
A small was added to the pins and a grub screw fitted though the outer section of the hinges
I also added a small hole (about 2mm diameter) to the inner section of the hinges so some oil can be added when needed
vecchioalfa
A sigh of relief now the door is on, the whole A post was rebuilt from scratch if you can all remember....
Door gaps are very good
No shims at all at the top and only a 1mm shm added to the bottom to get the gaps right
Well happy :D
vecchioalfa
The 8,2mm Long series drills are available here should anyone want any:
http://www.ebay.co.uk/itm/Twist-drill-d ... 3ce8317870
Obviously one drill will make one pin so you will need 4 drills..... ;)
The reamer you will need is an 8,20mm HAND Reamer, these have a tapered lead on them and will pick up in the existing holes, care is needed along with some cutting fluid when reaming them out. As some of the wear takes place on the original pins and some in the hinges 0,20mm was enough to remore all the wear from mine although you could go slightly bigger provided you can get hold of the right size hand reamer but not too much or the hinge will be weakened.
vecchioalfa
We are moving house next week so the car now needs to be moved, Shrew I will need your services mate!! I will text you :D
Incredible attention to detail - quite inspirational, although I will never aspire to such feats myself :lol:
As above great work chap 8-)
No problem mate, just let me have as much warning as possible, and I'll sort the day out for you.
Fantastic work as usual Adi, nice to see some more progress and those fiddly areas tackled brilliantly :P
vecchioalfa
Thanks chaps much appreciated ;)
NEG
Post by NEG »
Great work and ingenuity! These threads are a great source of inspiration, shame I don't have the fabrications skills to go with it! :D
