Manual turning of engine
Guys, I admit defeat. I've turned the engine over to put new cambelts on before, but with the engine out of the car.
So how on earth do you get a spanner on the crank nut to turn the engine over with the engine in the car? Can't get anything down there with the radiator there? There's no room.
So guys, what's the secret? Any tips? Any idea even what size the spanner/socket is required?
Thanks as always.
Thanks as always.
Re: Manual turning of engine
Could you put it in gear - 4th and push the car?
Good point, yes possibly got enough room in the garage if I'm somewhere near tdc. Just can't believe there's no other way. Perhaps I need an offset ring spanner....but what size...32mm? Anyone know?
Ah ha. Managed to get a socket on it coming in from under the radiator - it's 30mm. No room to get a socket wrench on though, so guess that a 30mm offset ring spanner should just squeeze on there....eBay I think. Will keep you informed of progress.
In gear with one wheel jacked up turn the raised wheel will work
Take the plugs out, and turn the crank pulley by hand....with a pair of gloves on!
Dave
Dave
Top tips these. Knew this one must have been out there since the birth of time!
Thanks all, will give them a try.
Take the plugs out and put a spanner on the nut at the front of the alternator. If the alternator belt slips just apply a bit of pressure to the belt and it will grip.
Thanks Simon.
I did try that one and yes it did slip. Didn't want to put further pressure on it, but if someone's tried it and it works then I'll definitely give it a go this weekend.
Thanks again.
Thanks again.
That's the way I turn our sprint over....works well
Thanks, worked a treat!
Eddie
Eddie
